Thought I'd solved my puncture problems with some Dr Sludge tubes but having dropped the pressures from 40 to 35psi I got a pinch flat and then on the same ride the replacement non-sludge tube got a conventional puncture. That night I acquired another bike which had tubeless ready tyres on it so I bought some Caffelatex sealant and two 20" tubes and had go at making it work…
Five hours later amidst a world of bubbles I was still no closer to getting the tyres to seat with a track pump. Before ordering some CO2 or a compressor I did more googling and found suggestions that if the tyre wasn't a tight fit you should add some foam tape under the tube.
Foam tape duely added, tyres were seriously hard to get on, but once in place inflated immediately without soapy water or sealant. By the next day one had lost most of its pressure so I popped to the chemist who kindly gave me a suitable syringe, then unscrewed the valve core, squirted 100ml of sealant into each tyre, pumped to 30psi and they appear to be holding! Who knows if they'll work in practice, I shall report back…
