I took the YT Wicked 160 out last Sat, amazing bike.
Half way around I noticed that in the middle cog at the back, when under duress, it seemed to jump or slip into place, strange, difficult to explain.
I thought it would just be misaligned or something, not used it enough for cable stretch.
I have just cleaned it now, checked the bolts etc, all is well.
I did notice that the top wheel of the rear derailure looked like the teeth were a bit worn. I gave them both a clean and the edges of the teeth on the top cog felt a little rough. I then compared them to the bottom cog and the profile / shape of the teeth are very different. The teeth on the bottom cog are very sharp edged.
Is this a problem
Are the profiles of the two wheels oon the SRAM XO derailure supposed to be different
Would worn teeth on the top rear wheel of the deraliure cause this jumping sensation.
Can you replace these easily as I dont want to have to go back to Germany on a warranty. YT Industries.
I can post some pics shortly
Thanks
