Viewing 5 posts - 1 through 5 (of 5 total)
  • facing a 73mm bb shell to 68mm
  • clubber
    i’ve got two frames which i swap parts between (rocky mountain element and spesh enduro). The rocky has a 73mm bb, the spesh 68. Fine with a ht2 chainset due to spacers but i’m considering using a square taper again and that’d mean two bbs. So any issues with facing the rocky down to 68mm. There’s plenty of clearance and the bb threads are deep enough.
    Steve-Austin
    just pick up a cheap chainset. it would be a lot easier
    scaredypants
    Now I’m not a clever bloke…
    can’t you just put a BB in each – with the same length axle but a different shell size
    I wouldn’t fancy repeatedly swapping a bb over, you’ll end up buggering a thread sooner or later
    nukeproof
    I’d just have 2 BBs…UN54s only cost a bit over a tenner.
    clubber
    yeah, i guess, you’re probably right. I just don’t see the point of a 73mm bb on an xc frame. And i have a decent 68mm bb already.
The topic ‘facing a 73mm bb shell to 68mm’ is closed to new replies.
