Hi MTG,
Firstly, if you haven’t already, download this brick dims table
http://bricksalesltd.com/Brickwork%20Dimensions%20Tables.pdf
Secondly, don’t use B&Q, they’re cr@p. Try the Wickes website, much better at telling you what will fit with what.
The 910 opening is a standard metric structural opening. I can’t remember what size frame it requires, but I think the door leaf to fit is 826mm.
Again, from memory, you need to allow 7mm either side of the frame (for building tolerance, and expansion/contraction). 910 – 7+7 = 896mm – 826mm leaf = 70mm total frame / 2 = 35mm frame thickness. Sounds about right.
HTH
PS, Self supporting cladding……..?
