The micro version of the Red Eye is brilliant as a lightweight get you home combination used with a Joystick. The only think wrong with it is that it’s so small it’s very easy to lose. Some sort of tethering mechanism would make sense, but then they’d probably sell fewer of them to replace lost ones…
The downside of the Red Eye generally, is that it plugs into the light’s smartpoint socket, so you csn’t use both that and a supplementary back-up cell.
The engineering and tech behind Exposure lights generally is excellent, though sometimes you wonder if anyone there actually uses the lights. Take the super-bright rear displays on the latest Strada which is the last thing you need shining in your face and the inability to use the standard remote switch with a back-up cell for the same reasons as above,
Not slagging them off, brilliant lights and great customer service ime, but sometimes they miss the obvious.
