I’ve had issues with my Exposure Flash/Flare lights as well including a new set that I ordered online (from Wiggle) which didn’t work at all straight out of the box.
They need a bit of tlc sometimes and it’s well worth having a back-up light – mine still very occasionally switch off or change from pulse to steady. Cleaning the contacts usually sorts it.
The Fibre Flare is nice but it’s not as bright or as focussed. Best place for it is on a rucksack, then it’s at the right height to be easily seen. Mine have never had any problems with moisture – if you are having problems like that, wrap the top and bottom bits in clingfilm!
