I bought a Diablo last year and find it fantastic. Use it helmet mounted to backup the handlebar mounted Chinese unit. Rarely use it on high and generally scroll between medium and low. No problem when wearing winter gloves and the helmet bracket works really well. The unit I have is the 975 lumen with just the 3 settings. My girlfriend has just bought the new 1100 lumen model; having borrowed my unit she couldn’t live without it!
The new unit has the ability to select a power band, tricky to explain but basically it allows you to pick a 75% (for example) and then cycle through high-medium-low in that power band; quite nice if you need that extra battery life.
The output of both units on high is very impressive and the beam has a good spread. I’d certainly recommend it.
