when a change of tyres can lose you over a kilo it gets a bit silly comparing things within a lb or so of each other.
ie: my (quite light for) steel HT can weigh 24lb with the light wheels and tyres on, stick the burly ones on and that changes to 27lbs immediately, but then I have another Steel HT that weighs nearly ~30lbs with a hub gear and coil fork so meh…
Things haven’t really changed in general trail HT land over the last 10-15 years, the weight has jsut moved around a bit and things have got better/stronger/longer for the same weight so the answer is still ~26lbs give or take 5lbs 😀
There’s no getting over it – >30lbs is bloody heavy for a hard tail. Most full-sus bikes come in under that weight.
My 29er is ooh about 24lbs.
The Plus bikes in MBUK I was reading the other day were around the £1800 maek and came in a range from 26lb to 29-ish.
And in the real world they’re all a lb or so heavier, due to optimistic quoted weights of small bikes without pedals. The look of disappointment when people put their ’26lb trail full suss’ on some proper scales is always a delight 🙂
