I got my current MTB in March and it was fitted with a KMC chain. Afer the first few rides on it I started breaking the chain over a few rides, sometimes multiple breakages per ride, so I decided to change the chain and went for a SRAM chain, since my other drivetrain components are SRAM. I didn’t go for the ultra lightweight racing chains with hollow links, or the cheapest chains, I went for a mid range Nickel coated ‘bog standard’ chain. This has stopped the breakages, however, after starting to get chain suck i’ve just measured the chain stretch and bu**er me, the chain is due for replacement! I’m pretty mechanically sympathetic to my equipment, so i’m not one of those who tries to ram the chain up the block while under full load on a steep climb, I clean and lube after every ride pretty religously, so i’m somewhat surprised at the short space of time for the chain to stretch/wear. I’m not sure how many miles i’ve got on this chain, but i’d be very surprised if it is much more than about 50 to 60 on cross country style riding.
What is the average expected life of a SRAM chain for XC riding? I have been using WD40 dry lube to lube the chain, which seems to be effective in terms of quietening down the drivetrain noise, but maybe its not as good as normal wet lube?
