Viewing 14 posts - 1 through 14 (of 14 total)
  • Excel help – adding columns
  • sing1etrack
    As far as I can tell, the max number of rows and columns is preset. There's 65,000 rows yet only 280-odd columns (up to IV). Is there a way of adding more columns? Cheers!
    uplink
    256 – I believe & no
    mrmo
    if you need more columns, why? buy Excel 2007, or try and create lookups between Worksheets.
    sing1etrack
    A girl at work's trying to do a holiday chart with all 365 days going across – it's not happening for her though! As resident Excel 'expert' I'm meant to know how to sort it out……
    uplink
    Use the columns for months & the rows for days or split it into 2 spreadsheets
    mrmo
    i would have thought it would make more sense to run days as row headings and i am guessing staff names? as column headings, then run over a number of worksheets if you have more than 256 employees?
    Tim
    Bin out the weekends?
    uplink
    I take it maths is not your strongest subject? 😀
    Tim
    I made the (admittedly large)assumption that it was a mon-fri job
    so binning out 2 days a week that woudnt be used – about 100 less columns
    should fit in less than 280 columns
    HTH!
    uplink
    indeed it would, unfortunately there's only 256 available 🙂
    Tim
    I assumed the OP was correct 🙂
    reggiegasket
    you are stuck with 256
    or buy 2007 which is unlimited
    Stoner
    Standard request from secretaries trying to do tables in Excel instead of Word 🙂
    Turn it round the other way and use the rows.
    Or use Windows Excel Fisher Price 2007 for Dummies 😉
    allyharp
    Bit of a longshot, but…
    I know if you want to run a pivot table with more than 65000 rows you can link to a csv file and run it from that.
    There might be a similar workaround which applies to columns and could be used in a non-pivot table situation?
    That said… I'm not sure how exactly you'd store the information in csv format without using Excel 2007 and saving it as a csv file!
The topic ‘Excel help – adding columns’ is closed to new replies.
