What razor were you using?
+1 – I went DE to get away from sore neck, and it’s worked a treat, the blades are also SOOOOO much cheaper.
For info
I’ve got an Edwin Jagger DE (short handle), I’ve been experimenting with Derby and Feather blades.
I started using pre-shave cream (menthol stuff – bloomin cold), and used a limes and pomegranate soap with a super Badger brush. I ended up dropping the pre-shave as it’s not needed with the Derby blades, but the feathers seem to irritate me. The brush is a wonder, and helps lift the hairs a bit more.
I think the main point around DE or Shavette shaving is that it forces you to take time, whereas the cartridge ones leads you into slapping on any old cheap gel, and quickly getting the task over and done with (not always with good results). I also went the new man route and use a natural aftershave cream 8)
