Viewing 3 posts - 1 through 3 (of 3 total)
  • Entry Level MTB – Bargains?
  • soobalias
    Im looking for two basic mtb's – in medium size (17"/18")
    current favourite is the Dawes XC2.0
    http://www.bikes2udirect.com/B2821.html
    Anyone know anything about the supplier?
    Anyone seen any bargains out there, keeping it under £400 please
    Northwind
    Carrera Kraken, prices vary madly but right now it's £380, which makes it very nice indeed. Only shortcut in the spec is the truvativ crankset, everything else is solid enough. I could be wrong but I think the frame is the same as the old Fury (£500 range) though with a little less butting. Nice proven geometry. (I think the old frame was the same as the Mongoose Amasa, oddly enough, just with different cable runs)
    A lot of bikes in this price range come with XCR forks… These are actually pretty nice when they work, but you need to stay right on top of the servicing- clean after every ride, strip and clean whenever it seems like a good idea. This isn't a big deal, it takes about as long to strip and clean them as it takes to lube a chain but if you don't do it, the plastic bushings wear and the fork develops a bit of slop, and will judder on compression, not nice. But keep them in good condition and they're better than a Dart 2.
The topic ‘Entry Level MTB – Bargains?’ is closed to new replies.
