You said you rode it? It’s quite a short cockpit for the stoker, how’d he/she get on?
It was my brother, & it was just to see if it held together. Wasnt used with two chainsets, but I guess it could have.
Line up the rear bike over the front bikes seat tube, insert seatpost & shim. There would be some heavy jiggery pokerey, cutting and welding to get the dropouts and angles correct but pretty sure it could be made to work.
Thats exactly how it went together, I bolted the crank into the dropouts, then lined up the clamp & slid the seatpot through, then the shim.
The plan was to buil a frame for a long seat, like an xtracycle.
I’d designed a seat unit for my two lads, that would lock in to place. To be honest, it rode fine, but you underestimate how much room it takes to maouvre something that long.
iain, I did a simple analysis in Ansys, but cant find the file. It basically showed a shear load on the axle, & a heavy compression load on the seatpost joint. It also showed a heavy shear load on the seatpost, between the clamps. If you can imagine, the rear frame is pushing the seat post forwards, while the front frame is pushing the post rearwards but is further impacted by the rider weight causing a bending moment. I modelled in a length of steel tube slid inside the seat post & this beefed that up nicely. It showed the joint under compression from the front & rear.
I’ll try & dig the Ansys file up, but I’m more CFD based than Stress.
