I will be installing some V4 engineered floorign (A104) in a couple of weeks. Having done a modicum of research I have a number of installation options. Its going on a wooden floor that has a hardboard covering (from previous carpet install). Any thoughts from those in the know much appreciated –
1) Should I rip up the hardboard so that I’m installing on the floorboards instead, or leave it in situ as it helps level things up.
2) Choice of Underlay – I understand that I don’t need a vapour barrier as its onto a suspended wooden floor.I understand fibreboard is best
4) Direction of planks – the manufacturer says run parallel to longest wall, which is also parallel to the direction of floorboards. The longest wall is only 0.4m longer than the shorter wall so doubt it matters. Read eslewhere that laying perpendicular to floorboards is best practice. If I’m keeping the hardboard down can I lay whichever direction I like?
I think thats all, any further tips most welcome.
