Hi
I’m fitting an engineered oak floor in a week or so. I have started looking at the underlay but I’m not 100% which type I want / is best. My options seem to be a separate one piece damp proof membrane and an insulation without a membrane or an all in one insulation/membrane where the membrane overlaps and gets taped.
My thoughts are that a singe membrane is always going to perform better as there are no joints but a taped and lapped joint should also perform well as long as it correctly installed.
Any recommendations on the underlay? ideally around 3mm and I want the best insulation and acoustic properties I can find.
I have seen one called Novostat Comfort gold which is a combined insulation/dpm. is this type any good?
I have only ever done fully glued solid oak before but this engineered flooring came along at a price too good to turn down and should be a quick job which will do until we extend in a few years time.
Thanks
Andy
