Firstly, I don’t really know if it is running hot. The gushers is about half way between hot and cold (where it’s always sat), the truck runs fine and neither black nor white smoke from the exhaust.
I broke down the other day. We had a new fuel pump and filter. Whilst the bonnet was up, the mechanics pointed to wry low oil and leaking seals on the engine. They were replaced and the oil and oil filter changed too
With the seals on the engine leaking, it was obviously a bit oily.
I just lifted the bonnet to add windscreen-washing water and to my uneducated sense, the engine was too hot. I’d driven about 20km, sensible B road driving. Checked the oil an there was the faintest wisp of smoke, comimg, I think, from the dipstick hole. The fan wasn’t spinning unusually. Everything seems to be running fine. Temp gauge is normal… Should I be worried? Should I be checking anything?
Thanks
