Last post before I put it in the loft till I can ride again, rest of the bike seems to have sold. Medium Black Ellsworth Epiphany 5.25 inch travel, with XTR front mech and Hope clamp. Can be built sub 26 lbs. The frame is in pretty good condition as you can see from the pics. It has 2 very small dings in the bottom which are out of sight and now covered by heli tape, they do not effect the strength or look of the bike, argos cycles can fill them in for £10 a pop if your that bothered, but as they are out of the way you cannot see them (flash makes them look worse than they are). All bearings are smooth and no play at all, The BB needs to be chased as it has a ½ cm thread, you may be able to get a BB in with a push but ideally it needs to be chased (around £15 from a good LBS). I am only selling due to spine surgery and more on its way! I have only just stripped the bike down this weekend. I was after a fair bit more but I am selling for £600 inc the xtr mech and clamp. Will be posted insured and tracked. Or collect from Bristol. Patriotspyke@yahoo.co.uk
