Get XT’s m785’s instead,have both much prefer xt’s ( almost fit and forget)avids always need a tweak now and again.
Get Avid X9 Trails instead, have both much prefer Avids ( almost fit and forget) XT always need a tweak now and again.
Seriously though, I’ve got some X785s, had new XTRs, and Deore. They start off great, then go a bit spongy over time, and then air hides in them. Days of hanging the lever upside down, banging the caliper, pushing and pulling the oil. Still a bit spongy.
Conversely, the Avids, over time end up a little spongy. I pop a syringe with 2ml of oil onto the lever, pull the plunger so it pressurises the system, and the air bubbles go into the syringe, replaced with new oil. Then they’re back to being awesome.
Avids are far more modular (so you don’t just lock up), more powerful when fully pulled, and have longer levers – so more adjustable for where you have your levers in combination.
It’s horses for courses, Shimanos are great brakes, I’ve had three of the new style fail at the seals. I’ve also had two 2012 Avid Elixirs fail due to seals, and corrosion. The X9 trails have been spot on for about 6 months now, needing one quick lever bleed.
You wont be disappointed with either choice. But the Avids are better 😉
