Had the same heat related issue on my son’s Spesh Carve with elixir 3’s.
So we could get out riding yesterday I had to bled off a little fluid as they front brake was locked on.
They still were not good. They fouled the disc despite repeated attempts to re-align the caliper etc.
When we stopped for a rest (even leaving the bike in the shade) they made a horrendous noise when we set off again and we ended up cutting the ride short.
A set of deore will be ordered on Monday.
Just a quick question. His set up is 180/160 (f and r) – can you use the same rotors or will there be an issue? I seem to recall that the 180 rotors from avid don’t line up with shimano calipers or something? Is that right?
Hope you get yours sorted OP.
