- This topic has 133 replies, 55 voices, and was last updated 13 years ago by mrmo.
Electronic Gear shifting Yay or Nay?
GEDAFree Member
You have not really sold it to me what exactly are the benifits?
Maybe an analogy between new cars and old cars. Old cars were based on mechanics so could be fixed and fettled with a bit of knowledge and the right tools. New cars are full of electronics so a car with a perfectly good engine and body work can be a write off if the electronics are broke.
I like bodging and fixing myself and I like cheap parts and don’t have any issues with the way I change gears slowing down my ride. I can’t think of ever coming to a situation where I would think if only my gears could change with the light touch of a fairy and smooth as butter (Is that the only advantage?). Ok maybe on a steep muddy climb if something could instantly switch gear to the one I didn’t know I needed.
Its not really like suspension is it? As that effects speed, how much of a hammering your bike takes, is a skill compensator and makes technical trails less technical. Suspension would also never have developed as quickly if downhill biking have not overtaken XC riding as the main money driver in the sport. Racing technology is also not always in the best interests of the masses.
I can’t imagine an electronic dérailleur will ever be cheaper than a manual one.
Big-DaveFree MemberAre Surly coming out with a single speed version?
If they did it would come in an odd colour, be heavier and slightly uglier than the alternatives and have a stupid name.
beanieripperFree Memberdont get it, used sealed xt cables for years and i dont think i ever get em clogged… whatever next, electric brakes??
crazy-legsFull MemberYou’re forgetting that people used to say this kind of thing when Shimano went from 7 -> 8 speed, then to 9, then to 10. Every single time, people would be writing letters to magazines or posting on forums – what’s wrong with The Way Things Are, why do we need to change?
This is the same, it’s called progress. At the moment it’s the same as 8 speed XTR was all those years ago, only available to sponsored racers or the very rich but within a few years it’ll be commonplace on mid-high end bikes.
nickcFull MemberNot a chance. Its too complex and expensive
And your answer is hub gears? Because they’re not at all complex and expensive are they? 🙄
Price will come down, reliability will go up, (not that I’ve heard reports of Di2 being unreliable, quite the reverse in fact.) Battery lasts for months, cables are sealed, they only issue are the folks who regularly snap off their mechs I guess, and if that’s a common issue for you, well you’re hardly going to be interested.
TandemJeremyFree MemberNo – in reply to someone claiming this is the future – hub gears are the future. Far more bikes running hub gears in the rest of Europe now.
Electronic shifting is a very small market interested in the lastest goodies and that don’t care about the price. Its all about marketing.
Still fails the Chapman test – simplify adn add lightness or KISS
nickcFull MemberStill fails the Chapman test – simplify adn add lightness or KISS
[shrugs/], so does your solution…
traildogFree MemberI’m not sure hub gears are the future as I cannot see how they’re going to make them more efficient. That doesn’t matter when you’re running a town bike, but it does on a more ‘performance’ orientated bike. And the cable can still clog, which again isn’t that much of an issue on a town bike.
Electronic shifting is currently a very small market because it’s only available on the latest top of the range groupset. It’ll become cheaper and more and more people will use it.
I’m sure plenty of people don’t clog cables, but the problem does exist and so does cable stretch. Look at the SRAM vs Shimano thead and there are loads of people saying how they struggle with indexing on Shimano, which suggests they cannot setup cables properly.
I run fully sealed cables on my cx bike and I will eventually need to change the cables at the end of a season. If electronic shifting improves this then I’m sold.
TandemJeremyFree MemberI didn’t say that hub gears were the best alternative to dérailleurs. They are however the future of the European bike – dérailleurs will / are becoming a small niche outside of the UK as hub gears become better and cheaper.
Thus the electronic shifting will be a small niche in a small niche – it will never have the huge volume needed to bring costs right down.
its still a solution in search of a problem. Its only going to appeal to a small number of bike tarts
maxrayFree Memberdérailleurs will / are becoming a small niche outside of the UK as hub gears become better and cheaper
Not even slightly convinced. Do you have any facts to back that up TJ?
nickcFull Memberhmmm, you could apply the same arguments against hub gears in favour of electronic shifting. Thing is, mountain bikes are niche anyway, and in terms of price; even Deore stuff is silly amounts of money in comparison to what you can buy a fully functioning dérailleurs for. Hub gears have been around for years already, and they’re still heavy complex and expensive.
I can’t see manufacturers of dérailleur components moving all their production to hub gears, but I can see (and it’s happening already) those same companies having an electronic shifting version. All the roady teams using SRAM and Campag will be screaming for a version of Di2 (campag have already made one), and what goes on in roadie curcuits always filters into MTB racing. Couple of years down the line there will be an Ultegra and XT version. It’s never going to be as cheap as mechanical shifting, but then again no-one has suggested it will be.
crazy-legsFull MemberDesigners/engineers have been trying for years to come up with an alternative to the dérailleur and they’ve failed. Hub gears are heavy, complex (OK,l I’ll give you that they’re reliable/need very little servicing but when they do go wrong, they’re non-user-serviceable) and make it a PITA to get the rear wheel in and out.
The best solution in terms of removing/replacing the rear wheel, changing the cassette, ease of use, light weight etc will, for the foreseeable future, be the traditional dérailleur system.
Electronic shifting removes the need to adjust to compensate for cable stretch/dirty cables, removes the heavy complicated mass of ratchets and pulleys inside the shifters and makes it easier than ever to change gear under any conditions. OK, it’s expensive but prices will come down as it becomes more widespread – this is still first generation gear remember. It’ll get lighter and cheaper, especially once SRAM and Campag introduce some competition to the market.
Within a few years it’ll move onto MTB groupsets too.
TandemJeremyFree MemberMany of the bikes in everyday use in Europe are hub gear already – our market is very different to that in Germany and Holland an so on. Hub gear, roller brake bikes are common over there.
Electronic shifting will always be a small niche – STWers are not represenative of the gernral cyling population in the UK and not reperesentaive of cyclist europe wide.
I am sure it will be common amongst racers and nichewhores – but it will not spread beyond this smallmarket segment. Thus Di2 is only the future for this very small group.
In contrast to the small group who would find this useful there is a much larger group of utilitarian cyclists Europe wide who ride hub geared bikes for their simplicity, reliability and so on.
Don’t overestimate how small the “enthusiast MTB” group is in the general scheme of things
thisisnotaspoonFree MemberTJ, your saying STW isnt a relevent sample of the cycling poulation at large when the discussion is about would the STW poulation shift (pun intended) to electronic shifting.
Yes a hub gear is great on a town bike doing a couple of miles here and there like the BorisBike or VeLib which will always demand an entirely different comprimise (heavy, low efficieny, cheep, reliable) to mountainbikes (lightweight, reliable, high efficiency, price is less of an issue).
Hub gears have no future in MTB, gearboxes yes, but hub gears will be the preserve of town bikes and tourers.
leggyblondeFree MemberTJ, your saying STW isnt a relevent sample of the cycling poulation at large when the discussion is about would the STW poulation shift (pun intended) to electronic shifting.
bang on.
I can’t wait for electric shifting to become commonplace for enthusiast cyclists. self adjusting gears and no gritty cables will be amazing, it’ll be like moving from v-brakes (work well in certain conditions but need constant fettling) to hydro discs (work well almost all the time with an occasional big service.)
TandemJeremyFree MemberPeople were claiming this electronic shifting is the future. I was merely pointing out its appeal is to a niche within a niche and thus strictly limited which means it will not become cheap as the economies of scale will not be there – it will remain XTR not deore or alvio
leggyblondeFree Memberit will remain XTR not deore or alvio
why so? if 9 speed, rapidfire, hydro discs etc etc have trickled down, why should electronic shifting be any different?
radoggairFree MemberMany of the bikes in everyday use in Europe are hub gear already – our market is very different to that in Germany and Holland an so on. Hub gear, roller brake bikes are common over there
But you are talking about a totally different kind of bike. The ‘other’ european market are generally town bikes, not the type we are talking about, i.e. trail/race bikes. Hub gears have been about for years now, my friends had/have them and i have never been convinced. The weight and weight distribution is the main concern, so much weight in the rear of the bike. I would be potentially sold if the system was very lightweight ( lighter than the drivetrain of an equivalent mech’d/cassette’d bike) and maintenance was easy ( and that includes on trail). By the way the ‘chapman’ theory you use shows you how things evolve. ‘Chapman’s Lotus’ company are modelling cars weighing 1350/1400/1450kg with big power (and big price £120k)which was totally against his ethos, although the MD said his lightness was not about cars but against other cars in its class . Great twist
molgripsFree MemberKISS? Why the hell should I?
If I want reliable self-adjusting shifting that’s not really heavy and inefficent, who tf are you to tell me I’m stupid?
Shimano have invented a great many of the things we use and appreciate every time we get on our bikes. If they and all the other manufacturers been keeping it simple we’d still be using friction shifters on our downtubes and clips and straps, would we not?
Got gears? Got suspension? Pneumatic tyres? If so, then stfu about keeping it simple.
If Di2 has worthwhile advantages over cables such as self adjustment and reliably snappy shifting then it’s a good thing. Especially given that the gear cables are now the last thing I have to faff about with on my bike. However I’ve not ridden it SO I AM KEEPING AN OPEN MIND! Something you seem to find hard!
crazy-legsFull MemberPeople were claiming this electronic shifting is the future. I was merely pointing out its appeal is to a niche within a niche and thus strictly limited which means it will not become cheap as the economies of scale will not be there – it will remain XTR not deore or alvio
Years ago, suspension was considered heavy / unnecessary / expensive, then it became a preserve of DHers only, then XC now it’s found on £80 Halfords specials (and the good suspension forks / shocks are light, adjustable, reliable and (relatively) cheap considering the price of suspension 10-15 years ago – remember when RockShox Mag 21 SL Ti forks were £650?!).
It’ll be exactly the same with electronic gears.
molgripsFree Memberand (relatively) cheap considering the price of suspension 10-15 years ago – remember when RockShox Mag 21 SL Ti forks were £650?!)
Forks have stayed mostly the same price, just got loads better. Have you seen the price of Fox lately?
TandemJeremyFree Memberleggyblond – because of the small size of the market place.
guys – you miss my point – its a niche within a niche – its attractive to some enthusiasts but that is all thus it will never get the market penetration – thats my bet.
crazy-legsFull MemberForks have stayed mostly the same price, just got loads better. Have you seen the price of Fox lately?
Exactly what I mean.
The Judy DHO forks were over £1000 when they first came out (6″ travel triple crowns, elastomer sprung).Look what £400 buys you now – adjustable travel, coil or air sprung, proper oil damping, loads of adjustments.
Gear shifting is just going along the same road – they won’t have come close to making back the money they’ve spent on R&D of Di2 yet but it’ll come and then it’ll get cheaper, better, lighter…
molgripsFree Memberits a niche within a niche
I disagree. If it does what it promises and becomes reasonable, it’ll be popular.
And I got annoyed because I frigging hate people saying ‘KISS’
thisisnotaspoonFree MemberWell d2i exists on D-A, so I’d put money on it being on XTR in 4 years time. And like 10speed, once its been trialed on D-A I reckon we’ll see it on XT/Saint as well.
The dereilieur isn’t perfect, but it is efficient, light and it does work reliably (rock strikes aside) and wear isn’t unacepably quick. Hub gears like dereilieurs are still basicly the same and fill the same niche’s as they were 50 years ago, we’re not going to see one replaceing the other.
AndrewBFFree MemberGood review here http://weightweenies.starbike.com/forum/viewtopic.php?f=5&t=70101
I’m intrigued… one to keep an eye out for and see how it develops.
molgripsFree MemberGood review that.. really shows you the advantages of the system.
However I just googled for prices.
HOLY F*CK!
jfletchFree MemberIt will get cheaper than mechanical eventually. No doubt
Look at how previously expensive electric items are now dirt cheap (or massively more competent for the same price) and have removed the need for a purely mechanical solution. Bike kit will be the same with current D2i levels of awesomeness tricking down to deore and below and D2i getting fancy new tech as well such as wireless or more trick shifting prediction etc.
scaredypantsFull Memberelectronic shifting and one of those honda “gearboxes” 1×10, wide range cassette, centralised within the fame – that’d do me
GEDAFree MemberSo it seems like the advantages are a bit like driving an automatic car compared to a manual. As I said I never had any problems with shifting but I do have fully sealed cables. There are plenty of times when I was being shaken to bits riding a fully rigid before suspension but never think I need a better shifting solution.
The review above talks about the gears shifting under any conditions and not missing a shift. I am curious, how does electronic shifting affect this as it is a muddy chain and block that messes that up much the shifting far far more than the cable?
molgripsFree MemberIt will get cheaper than mechanical eventually. No doubt
Purely electronic stuff is cheap because of the economies of producing it. Di2 is electronic but also complex mechanically too. It’ll get cheaper for sure but I doubt it’ll be as cheap as normal.
I don’t think it is.
With a normal shifter, it clicks the same amount of cable regardless – sometimes it’s not enough when the system’s cacked up and you don’t get your gear. The electronic one presumably knows where it is and can keep applying pressure till it’s in the right spot. No faffing with extra pressure on shifts etc.
GEDAFree MemberOk. So it is due to the indexing being in the dérailleur instead of the shifter. Still went out last Sunday and it was really really muddy and it did not affect the shifting much at all. I did start going biking with a GPS, heart rate monitor and camera but it felt all wrong to have all those electronic gadgets.
AndrewBFFree MemberHow does it work? It is stepper motors (v. reliable and low power reqs) that push/pull the mech?
I’ve also read about how the mech is trimmed dynamically to minimise misalignment and strain on the chain.
If the above are true then this could be a winner. It *could* eliminate dérailleur tuning (the reason I went for Rohloff & singlespeed on my bikes – CBA with tuning the gears after every ride in the crud in the Peaks). Let the sensor / motor do it.
Electronics (and stepper motors) are dirt cheap in volume numbers. And would attract the Xbox generation who’d want to have a cool gadget on the £300 starter bikes.
Yes, very expensive right now – but comparable in price to Rohloff. And as mentioned already there isn’t much more to squeeze from hub technology. Electronics and motors and batteries are still on a scale down curve, especially with electric cars around the corner, all such things will advance in leaps and bounds in the years to come.
molgripsFree MemberStill went out last Sunday and it was really really muddy and it did not affect the shifting much at all
That’s exactly what I was saying. Mud isn’t the issue, it’s cable griminess.
oliverd1981Free MemberI just hope they do it in 9 speed, 9 is enough.
I really like the idea though.
clubberFree MemberA few comments
– IIRC di2 is lighter than non electronic dura ace EDIT oops di2 is 50g heavier apparently though that’ll drop or go the other way as battery tech continues to improve.
– by all accounts it’s incredibly reliable and for mtbing in the future has the advantage that it’s self adjusting.
– battery life is ages not just a couple of rides so you have to be actively lazy to have problems there
– TJ’s comments are no different to people’s claims about indexed shifting when it came out. Old, narrow-minded and arrogant.
– I don’t expect it to become common or widely used for a while yet – there’s a way to go on cost reduction for that to happen.And some comments to back at least some of that lot here:
http://www.cyclingnews.com/features/pro-bike-adam-craigs-rabobank-giant-tcx-advanced-slGEDAFree MemberSelf adjusting means that it knows if it is in gear or not, not just indexing on the mech. Is this how it works?
molgripsFree MemberI would expect so yes. It’ll know from the angle of dangle I expect.
The topic ‘Electronic Gear shifting Yay or Nay?’ is closed to new replies.
