So I’d discounted latching relays as the ones I looked at (magnetic and mechanical) need two momentary switches, one to switch one way, and another to switch back. But just had another look after Maxtorques comment and found there is another type, impulse relay, which looks like it is designed to work off one switch, that sounds perfect.
All the switches have four contacts, including the latching one which has an ‘on’ indicator light. Pretty sure they are all backlit as well. So I’d guess the latching one uses all four to enable the backlight and the ‘on’ lamp, and the others probably have an unused pin.
What type? errr…four pins in a vertical arrangement, pretty sure there are loads of spare plugs on the wiring loom that I can chop out and reuse…the switch blanks are used for things like raising and lowering air suspension, heated rear screen on minibuses, heated seats etc.
Van is going in for repairs next week (three days before the warranty expires!) It has an earthing issue I think which is affecting the instrument warning lamps. So I won’t be getting stuck in until its fixed.
Aracer…the facia included two worklight switches which I thought were both latching, I also naively assumed the front fog light switch was latching and could have checked the one I already have fitted. When it turned up, it turned out that they had fitted two types of worklamp switch and only one is latching! So in retrospect, I would have spent £18-20 on two or three switches rather than £30 on six!
