I’m just in the middle of making some floor standing lamps and was hoping for a little wiring advice from the knowledgeable electrical wizards here.
Wood is my usual realm and what I’m basically doing is buying what are essentially desk lamps or cheap Ikea floor lamps, and pimping themconstructing a tall base with 3 or 4 legs to add a bit of fanciness.
Here are some I made earlier…
Basically, I have a plastic Ikea light fitting which uses two-core cable, I’ve bought some really nice fabric-wrapped coloured two-core cable and I need to join them together so as the cable is long enough for a foot switch.
How can I do this safely and the lowest profile possible? (The wiring is concealed in a groove I’ve run down one leg which later gets wood spliced in to cover it)
Can I use bullet connectors such as you get for car wiring like these below without the lamp exploding into flames?
If this is blatantly unsafe, I guess I can buy new bulb holders?
I’ve tried to dismantle the Ikea bulb holder to re wire the new cable right into but it’s a push fit, style thing you can’t take apart without breaking.
Instead of bullets, use in line crimps. Butt crimps.
Stagger joints and use heat resistant shrinkable sleeving. The cable should really be clamped to avoid strain on the crimp. If you can make the groove big enough a cable clip either side of the join would do.
Optimally you should use a proper crimper, not one that you would use on the car. Ratchet Crimper.
Rich.
PS You’ll only die if you don’t turn the power off.
PPS – soldering is acceptable, but you should still clamp the cables.
