Hi guys,
After my project to run some strip lighting sustainability off a small wind turbine failed miserably, I am stuck with this motor I purchased off ebay. I don’t have the space for it to lie around so I’m looking to sell it on to
someone who actually needs it. The thing is, I know next to nothing about the value.
This is the blurb I had when buying it originally:
“This is a DC drive motor made by ‘Groschopp’ of Germany a world leader in precision drive motors.
Model EM 94-60
Its 220mm long x 100mm wide and stands 80mm high, requires a DC voltage of around 180 – 200v @ only 0.075A applied to the field coil
the armature will run from 5 – 235 volts DC obviously reversible with a reasonable torque.
The shaft is 10mm dia. Rated at 120 watts. @ 3,000 rpm.”
There also seems to be some sort of greeny putty on the windings…
Any help will be kindly appreciated 🙂 Have a good evening!
As andl says, put it back on eBay. It’s worth what somebody will pay, put on an auction with the best description and photos you can, and a postage cost that ensures you can actually send it without loss if it goes for £2
