Hi all
I’ve got a strange one on my road bike.
It’s an Orbea Orca carbon frame with carbon steerer.
I flipped the stem as got a sportive coming up, and ever since it’s made a v loud creaking sound under pedalling force but only from the left pedal (if I pedal one footed with the right there is no creak).
It creaks when the crank is just before the bottom of the stroke.
It has a low creak but also a louder higher pitched crack sound.
Could this still be the headset?
The creak magically appeared as soon as I’d flipped my stem so I assume it must be related.
I accidentally undid the compression bolt adjuster (as well as the top cap), reassembled it and put it back. It’s an fSA compression bolt and I’m not sure how deep to insert it (ahem).
You can screw in or out the top cap from the assembly body to elongate or shorten it, hence effecting the depth it goes into the steerer tube. I think I should get the expanding wedge part to sit under the bottom/lower stem bolt – but I could be wrong.
Any help would be awesome and very much appreciated.
Thanks all
RT
