Had the device for a few years and it’s been good apart from one incident when it switched itself off and a software updated sorted that issue.
However I went to switch it on before heading out yesterday and it turned on, went through all the start sequence then turned itself off straight away. I tried it a few times and it did the same thing,
Thinking it was flat, I plugged it into the charger and it was 75% charged. It stayed on and didn’t turn itself off when plugged in. Took it out the charger and same as before, turning on then switching itself off.
The last few rides were weirdly recorded with them being something like 23, 25 and 30 hours long 😯 so I deleted those…..
I did a factory reset through the menu, nipped out for a ride and it was fine.
Just wondering if anyone else has had the same issues ? Like I said, it appeared to be fine but I want to be sure before I rely on it to navigate me somewhere.
Thanks.
