i have a few year old edge 705, that has worked great up until a particularly wet ride on Wednesday night!
Basically, whilst it was plugged in downloading the data,it kept flashing up with “external power lost”.. this stopped after a while once i had unplugged it.
then the charge screen/connected to computer screen is permanently displayed, and the device wont power on or off properly, sometimes it looks as if its going to start, but then it reverts back to one of these screens!
When i plug it into the pc, you can still open the folders etc in windows, but the unit still displays these screens!
i have tried both methods of reset, and again it looks like its going to reset, but the charge screen comes back on and stops the process!
I let the battery drain too, then re charged and its doing the same thing!
also updated software on garmin connect, this worked ok according to the pc, but the units still doing the same thing!
Quite annoying!!!
Anyone experienced similar, or is the unit completely ****!?
Put in a sealed container with rice, cross fingers for a day or two. Hopefully it’ll dry out. Best option would be to take the battery out and leave the whole thing in a container of rice to dry out.
I’ve left mine on a radiator on top of a few layers of t-shirts so that it’s warm rather than hot. SD card cover off, USB port cover off and leave it like that for a day or so to dry out. Did the job.
Water getting in can certainly make it behave oddly though IME you can usually tell it’s got wet as the screen gets misty from inside.
See if you can find some of the little packets of silica gel that you get in shoes / electrical equipment.
Find as many as you can of these and put the Garmin in a sealed sandwich bag with them in a warm or sunny place. 3 days later it will be as dry as it is going to get.
Silica gel is much better than rice for this if you can find it (they sell it on Ebay too if you can’t find any)
right, i have left it to dry out, the battery has drained, i’ve even disconnected it. it powers on, but its like its permanently plugged in, so the charge/usb screen never goes off, and when in menu mode,the little plug is showing as if its plugged in!
could the socket have got damaged or corroded by water ingress??
