No not really, but you try getting it set up so that it never ever does!
I guess you mean should it be rubbing against the side of the top guide rather than the top right?
Again, no this isn’t quite how it’s meant to be. You should havea pack of spacers that came with the device and you should be able to use these to shim the back plate either towards or away from the BB. In this case, you need to move the backplate towards the BB shell, so either remove some spacers or switch the thicker spacers for slimmer ones.
Of course if you’ve not got any spacers between the backplate and the BB shell your funked 😀
In this case you need to try and adjust the chainline of the cranks by adding removing any spacers you may have between the cranks and the BB cups.
Race Face cranks used to be good for this. It was about their only redeming feature!
