Im after a bit of guidance here.
I bought a new lower engine mount for my Scenic and fitted it at the end of July, it was less than £20, so Im not massively out of pocket.
Its not weight bearing as such and is just there to hold and damp the engine from swinging about on the two main upper mounts, dealing with fore / aft movement.
It was noticed by the mechanic that it had failed, thus allowing the engine to swing 2-3″. Now I’d say that less than 3 months use, possibly only 1000 miles would be a premature failure.
I’ve contacted the E-bay store twice in 2 weeks that sold it and so far they haven’t responded.
So where do we go from here?
Do I just suck it up or can I raise a case with E-Bay?
I’ve had things from E Bay fail prematurely before, I just contacted the seller who replaced the item FOC.
