I’ve got a SP PD8 hub which I use on my singlespeed all the time. The bearings had developed a fair bit of play after about a year of use, which is not great, but not much worse than a lot of other hubs I have tried.
Unfortunately you can’t just pop the cartridge bearings out and whack some new ones in.
You can get the hub replaced with a reconditioned one by sending it back to the importer (Ison) for £25. Unfortunately this involves dismantling your wheel and rebuilding which will cost you a fair bit of time (if you build your own wheels) or money (if you don’t).
