I’ve got 2 Shutter Precision PD8 hubs. One on the road bike and a PD-8X on one of the mtbs. I use an Exposure Revo front light which I switch between bikes.
Issue 1:
On the road bike, I recently installed a Busch and Muller Toplight View rear light on my pannier rack. Previously used an Exposure Redeye, but on the seatpost it occasionally gets blocked if I have stuff on the rack. I can’t see the light properly as I ride, but spinning the front wheel up by hand whenthe bike is on the workstand, or having a look when stopped and the light is powered by its standlight, its franly crap. Compared to the Redeye which is like the sun, I can only get one of the two LEDs powered up, and that only dim. I’ve checked the polarity of the connector (the other way it didn’t work at all) and the checked the current of the output of the Revo when stationary at the plug and at the rear light and its pretty much the same, so no major losses in the wire. As I say, the same output power up the Redeye to painful brightness. Any suggestions?
Issue 2:
Riding the other night, I got a branch caught in my front wheel. It pulled the plug out of the socket and also pulled the hub-connector around the axle a bit. Reconnecting, the front light, it didn’t turn on when I got going again. Sure enough I’ve checked and one of the wires got pulled out of the connector, put it back in and still nothing. Using a multi-meter, my hub isn’t producing any current at all (for refernce, the road-bike hub produces “some” noticeable current when spinning up by hand).
Again, any suggestions?
