Ive got a problem with the rear suspension on my 5 spot in that there is a lot of stiction.
Ive removed the rear shock whilst the bike is upside down and the rear end still will not move without firce?
So ive started to strip the rear end off and most of the metal bushes that go through the plastic bits pressed into the frame are very stiff?
Everything is very dirty too.
I am going to try and rebuild it all but i have a feeling that i will need some new metal bits (the bits with the spiral on that the grease runs around) as apparently there is a new design with a hole drilled into them to help the grease flow?
Any ideas??
