I finally managed to take my 09 dw five spot for a quick blast tonight and im having mixed opinions……..
ive come off a 2009 enduro and more recently a 2010 stumpy which both have fsr rear ends.
the dw spot feels completely different to be honest and just plain weird??
the back end on the spot feels like there is a ton of stiction in the bushings, even with no air in the shock it took some effort to compress the back end??
it was also clonking and creaking until i nipped up the bolts on the linkages, not a lot but just enough.
I have a set of steps that i like to clear on my old bikes and on the 5 spot i felt as thought i was going over the bars !! i can see why people install anglesets on these things too.
mind im running a 140mm thor fork which has been cut for the frame so i can put any more spacers under the stem. im still keen to try a long travel fork though.
the one big thing for me which is a concern is that when i was stood up stomping on the pedals every time the cranks come past the frame on the drive side the crank arm was clunking the swing arm a bit??
i take it this isnt normal ??
overall though i think once i get the shock set up and perhaps the bushing re-greased i might start to like it !!
