Kaesae is trying to be as helpful as possible to the OP
…he is trying to sell him something. Although the OP might get them free to try?
Hello SV, how are you ❓ first we need to determine what kind of bushes the shock is running.
For that neil853 needs to understand what the different inner lining colours mean. Grey is DU, red is DP and if the bushes are cream coloured then it’s a polymer for arguments sake.
Although the DU and DP bushes are identical they use a different kind of metal. Both are steel with a layer of sintered or porous bronze, attached to the porous bronze is PTEE impregnated metal. However there isn’t really any point in going into all that. DP4 will out last the DU bushes,
Here’s an extract from online.
The material of DP4 bushing is similar with DU bushing. According to the material is different, the color of inner layer is red. DP4 bushing has good wear and friction performance over a range of loads, speeds and temperature conditions. DP4 bushing has a very good performance in oil lubricated heavy duty hydraulic application. DP4 bushing offers benefits in applications where corrosion of the lead in DU may occur. DP4 offers improved wear and friction performance along with good chemical resistance compared to DU. It is applied to the forming machines, office equipment, medical and scientific equipment, packaging equipment, pneumatic and hydraulic cylinders, pumps and motors, railroad and tramways, textile machinery, valves, etc.
http://www.bombayharbor.com/Product/39066/Dp4_Bushing_Sliding_Bearing.html
Check to see if the bush is grey in colour, if it is then upgrade, however you should also be looking to make sure there aren’t any other factors causing the excellerated wear.
Gice me a shout via my email and I’ll try and help out, gotta go I have a lot on!
