Everything you might need!
middleburn rs7 square taper 175 mm in black with silver 5 arm spider – drive side only £30
Brand new KCNC 4 arm rings 44/32/22 Beautiful looking, Cost about £150 a set online. £80
Shimano M442 44/32/22 cranks with rings including Shimano Octalink BOTTOM BRACKET all in good working order £30
MRP 1x chain guide missing screw and has some damage but works £20
XTR external bottom bracket very little use £15
Rear air shocks
2010 rockshox monarch 4.2 165x38mm air shock taken from new bike ( more advanced shock than Rp23) £110
Rockshox 200x50mm bar air shock showing no signs of wear £60
Dt swiss nude travel adjustable shock 165mm x38mm taken from scott scale with scott tracloc handlebar remote in good working order £80
Wheels
Wheel set from trance X5 in nearly new condition including tyres: RIMS Alex DP-17 26"
HUBS Formula Disc: SPOKES Stainless steel: TYRES Kenda Nevegal 26x2.1'' Stick-E front, DTC rear includes qr skewers £85
Bars
KCNC sc bone flat bars 600 x 31.8 weight 120 grams; less than most carbon bars some marks and deformation on ends due to bar ends . £25
Commencal 50mm risers 680 x 31.8mm £16
FSA gravity light 25mm riser bars 680mm x 31.8mm very light at 270 grams in good condition with some residue where grips were glued on
KCNC sc bone 25mm scandium riser bars 680 x 25.4 weight 230 grams (less than most carbon bars) go well with exotic stem (see stems) some residue where grips were glued on £35.
Seat posts
New ex system seatpost 30.9mm but only 150mm long, good for DH bike £6
Giant A3 aluminium cut down to 210mm 30.9mm good for DH bike £6
Ritchey carbon seat post for Scott 34.9x 400mm £25
Brakes
Avid Juicy 3 hydraulic disc brakes in good working order with 180mm and 160mm rotors and adapters good working order £75
Shimano XT m775 disc brakes with 4 good sets of pads (3 sintered) . Well used but fully working (bleed when I brought them and still ok after 6 months of use) £110
New formula 203mm rotor kits (x2) with is to pm adapters for front and rear 27.50 each or £50 for pair
Ashima wind cutter 160mm rotor in good condition x 2 one with gold centre £9 each £16 pair
Ashima wind cutter 140mm rotor in good condition £8
Brompton by stronglight 53t chain ring guard £5
Drive train
Shimano SLX Shadow long cage 9 speed rear mech £25
Deore 3x9 shifters £20 very good condition work great
Deore front mech in good condition 34.9mm top pull £15
New XT 9 speed 11-34 cassette unboxed with old alloy lockring £40
Shimano hg 50 cassette 11-34 in good condition £12
32t bash guard 4 bolt £6
36t dmr bash guard 5 bolt some cosmetic damage due to removing seized bolts £6
Stems
Exotic 60mm 25.4 stem 99grams £18
Kore elite stem 90mm 31.8 bars weighs 130 grams £18
bikehut 50mm for 31.8 bars £12
Fire eye black crown stem for 25.4 bars 45mm reach £7
specialised stem 120mm reach for 25.4 bars £5
Tomac road stem 110mm, 26mm £5
New giant xtc / anthem derailleur hanger may fit other frames £6
661 veggie knee pads large in good condition £15
Saddle: WTB Devo HP Comp in very good condition £25
Fizik saddle – used but no damage - £20
Element lock on grips with red ends some wear £10
DMR V8 pedals look almost new but one side does not spin as it should £15
Titainium bolt up mtb skewers with red alloy caps – very light £20
Pictures at http://www.flickr.com/photos/47935905@N02/?saved=1
ask if the pic is not there ,
All parts include standard postage by royal mail. Offers welcome. Discounts for multiple items
will post either Friday or Saturday next week
Please pay by Paypal gift
Seller: Adam Robinson
adammadasquash at hotmail dot co dot uk
