kamina – can I ask why you preferred them? How did they compare with regards to torsional stiffness?
Well they where very light, at the time the lightest fork in that travel range (old Rev's where quite heavy with the thru axle). They where very stiff, I felt stiffer then the Pike I had (but Pikes are not that stiff actually, I would imagine new Rev's are stiffer). The fork used all of it's travel and was quite supportive on the mid stroke.
I now have a 2010 Float with the Fit cartridge. I can't get it to use the last 20mm of travel, and there is loads of stiction (only ridden for 3 hours till now though).
I can second what was already posted about the rebound adjustment moving easily when you lock out the fork, I had that problem too. It was pretty fast to correct though, and I also felt the rebound adjustment did more then it does on competitive products.
Mind you, I had the one with a 20mm thru axle.
