I had the 130mm DT version – virtually the same as Pace RC41’s, but maybe a bit better built & finished. I really liked the Launch Control, and the adjustable threshold on it was useful. However, although the fork felt quite plush, the damping left a lot to be desired – IME, it was not a patch on RS’s Blackbox damping, in fact, I’d say that a well serviced open bath Fox is better damped. I experimented with pressures and different damper settings, but could never achieve a happy medium between small bump sensitivity/cornering grip and decent mid-stroke support for steep rocky technical trails.
TBH, I thought it was a very nice looking fork, and the Launch Control was good. If you like forks with a very linear travel and can accept the compromises in the damping, you’ll probably like it.
p.s. FWIW, I replaced the DT’s with some Blackbox damped Revs, and I noticed that the guys I sold the DT’s to has also now replaced ’em with Revs!
p.p.s. just remembered, I had some problems with the Launch Control sticking or not engaging and had to have it repaired – luckily just within warranty.
