Viewing 7 posts - 1 through 7 (of 7 total)
  • DT Swiss 350 hubs convert to 20mm 110
  • chilled76
    Hi all,
    Got a 15mm dt 350 front hub. I’ve tried googling this and not for very far… can you convert them to go in a 110mm 20mm fork?
    BoardinBob
    Boostinator
    15 to 15 would be fine. 20 looks a bit trickier
    Northwind
    110mm isn’t boost, it’s just the normal 20mm standard (and why Boost is a complete bag of shite, while I’m on the subject). The 350s aren’t officially convertible so unless there’s a 3rd party route or a machining option you’re out of luck.
    It’s literally the only thing the 350 sucks at, this. And it sucks at it very suckily.
    deadkenny
    350 20mm hub is different, much thicker hub. I’ve got both 15 and 20 hubs, very different. There are options for 15mm, but 20mm is a dedicated hub.
    Getting a 15mm hub and axle in a 20mm fork however… not sure, maybe there’s a way of adapting the fork. Probably not practical from a strength / stability point of view.
    Northwind
    Own a Fox 36- comes with 15 and 20mm axles.
    chilled76
    Will this not work?
    linkylinkthingmebob
    nixie
    Not on a 15mm 350 no.
The topic ‘DT Swiss 350 hubs convert to 20mm 110’ is closed to new replies.
