Viewing 6 posts - 1 through 6 (of 6 total)
  • Dropping 4teeth on chainring. Do i remove 4 links from the chain?
  • medlow
    It’s a 1x setup.
    Going from 42 to 38 on the front.
    My gravel bike is getting ready for a few cross races and as I rarely dip into the lower end of the cassette I’m changing for a smaller front ring to help on the steeper bits.
    Is it as simple as removing 4 links from the chain to keep the same tension as I currently have?
    jamiep
    I’d prefer just to remeasure it using the big ring big sprocket method
    goss
    Went from a 50t+34t setup on my Croix de Fer to 46t+36t, same chain length.
    When it’s a 1x setup I would take out 1-2links depending on the current length of chain and cage..
    chiefgrooveguru
    No, because it’s only going around half the teeth! 😉 One full link will do it.
    medlow
    No, because it’s only going around half the teeth! One full link will do it.
    I thought it would be something like that.
    Surely that logic is correct.
    medlow
    Removing 2 rivets resulted in a perfect length.
    Confirmed with the big to big + 1 link method.
    Thanks guys.
The topic ‘Dropping 4teeth on chainring. Do i remove 4 links from the chain?’ is closed to new replies.
