Okay hive mind…
I have a nice wobble going on with the car at around 60mph… classic Honda drive shaft issue.
So, I’ve got the wheels off and on inspecting the drive shafts I can visibly wobble the inner CV joint cup. I’m guessing that there is some play in the splined coupling.
So, should there be play here? My thinking is that the splined joint should actually be reasonably tight.
If there shouldn’t be any play, and I replace the drive shaft, any guesses as whether I will need to replace the other half of the joint? Obviously, I’d rather not as that bit is in the gearbox!!!
Ta…
