Ive just bought a HD Ghost and discovered that the iphone app only shows 170deg FOV even with camera set to 90 or 127.
This seems to totally undermine the usefulness of being able to set it up using the app, as you do not see the FOV that you want to record in.
I also found that after using the app/turning off Wifi the display continues to show the 170deg view in the preview despite selecting 90 or 127 in the menu (and having 90 deg or 127 showing on the display). But it does record in the selected FOV but reverts to 170deg when recording is stopped.
The only way to clear it is to turn off/on.
Is this normal or is mine faulty?
How much do you use wifi setup in reality?
