Long is good, as it been put i have a body like an orangutan.
Yes but that is LONG.
Rule of thumb would be each degree on the seat angle adds/subtracts a virtual 10mm to the top tube, so a 76deg seat angle gives 40mm more room when stood up over a conventional bikes 72deg. So a your top tube would have a similar reach to a more conventional bike with a 710mm top tube! And that seat angle is very steep, are you 100% sure you can actually pedal at that angle, I know I can’t with anything steeper than about 74 or 75 deg.
Also remember that with dropper posts seat angles need to be ~2deg slacker as you’ve lost the 25mm of layback that normal posts had.
Your framebuider should be able to help, and would hopefully tell you when you’ve gone wrong.
