I've recenlty started double-declutching again after years of not bothering. My dad taught me to do it when I was learning, but is there any mileage in it, with modern synchro-mesh, or am I just going to burn my clutch out instead of my gearbox? Car is an 11 year old Focus estate....
Chat Forum
Double declutching and other things your dad taught you to do...
Posted 11 months ago #
I can't see the point of it myself.
Won't it be the gearbox that you wreck?
Posted 11 months ago # -
double declutching on a down shift still has some merit in matching engine and gearbox speed and reducing clutch wear whilst they get back into step but given modern synchromesh it's irrlelvant as far as reducing gearbox crunching etc is concerned.
and it stops you left foot braking as easily as well
Still do it all the time, but agree seems utterly pointless.
Was funny when driving small cars and revving harder, but now I have
a big turbo diesel.
J.Posted 11 months ago # -
My Dad taught me the opposite, I now only use the clutch to change up when I'm trying to get away a little quicker than usual. In normal driving I don't use it at all.
how does this work????
My experience of double declutching is that it's used solely by a) vintage car drivers who have to do it, b) race drivers with tiny flywheels, and c) smug gits who think it makes them superior.
cruzheckler - you depress the clutch once to put the gearbox into neutral, let the clutch back out, depress it again, select gear, let clutch out again.
Don't think I'll bother now though...
EDIT - Cougar - you may be on the money re the vintage car thing - my dad has a bit of a fleet of vintage cars / commercial vehicles / taxis but he's not overly smug!
I know this isn't a euphamism, but it ought to be
The Institute of Advanced Motorists stopped using double de-clutch shifting some years ago as it puts excessive wear in the clutch pinion bearing (IIRC).
As has been said, it's not necessary with modern synchro boxes. The Police advanced driving test continued using it for some time after (not sure if they still do) as it promotes unhurried shifts.
There's no advantage to using it, unless you like the satisfying feeling of blipping on the down-shift. Heal-and-toe rev-matching is more fun and more use IMHO.
you're supposed to rev the engine slightly between clutch dippings to get the engine,gear box and road speeds get into step too.
Never saw the need / point in a car (other than "because I can", see c) above), but it certainly makes for considerably smoother, faster changes with a bike's fully synchronous gearbox. After a while, I never touched the clutch for upchanging other than setting off, just hook a toe under the lever and press gently, match the revs on the throttle and the gear just plops into place.
Are you actually double declutching? This involves pressing the clutch to disengage the gear, letting the clutch right up, then pressing it again to engage the next gear. If so, it's a waste of time with modern syncromesh gearboxes.
If you are going a blipped throttle downchange, i.e. blipping the throttle while the clutch pedal is depressed, then that is a good thing as it matches engine speed in the new gear to wheel road speed. It's not necessary but good practice. Most effectively done by heel-and toeing as said above. All the new flappy paddle boxes do this on downchange
Where's Surfmatt??
You what now?
Bike, Mol.
Oh, the gear change lever.. right.. never could get the hang of gear changes on motorbikes. One down four up.. wtf..
cruzheckler, not sure how to describe it without a demo but you match the revs to the speed and have minimal presure the gears then just slip the stick across. Google "float gears" for a better explanation.
It is effectively what those paddle-shift gearboxes are doing.
Not really. The VW DSG has two gearboxes and two clutches to switch between pre-selected gears.
Not something you can do yourself on a car with one gearbox
It's to stop you accidentally shifting into neutral.
It's to stop me riding motorbikes. That's the real reason.
Although.. woudl shifting into neutral accidentally not be far more benign than shifting into first accidentally?
Well,
If you're rapidly rattling down through the gearbox, it's generally to get to first. I can't readily see any reason you'd want to get to neutral in a hurry, and I wouldn't relish the idea of suddenly needing to apply power and finding I was out of gear.
TurnerGuy - Member
molgrips - Member
Not really.
Yes it is. Agreed the VAG DSG boxes are double clutch but that's irrelavent to the point that TurnerGuy and I were making. As per my previous post, they do a throttle blip on the downchange to match engine and road speed.
Only actually necessary when you are driving at the limit, which you shouldn't be on public roads, but it is satisfying, and I do it all the time.
Fair point (I'm not concentrating well this afternoon). However, when changing down don't we all apply throttle as we let the clutch in, unless actually on the brakes at the time? Very jerky otherwise.
Yes it is
no its not
Throttle blip to match engine/road speed is one thing. Makes letting the clutch out smoother so everyone does it.
Double de-clutch matches gearbox input and output shaft speed, usefull if you have no syncromesh to do the job for you.
Shifting without the clutch is possible as the input shaft is still spinning (attached to the engine by the unusued clutch) so as long as the engine is allowed to slow slightly the input and out spin aproximately the same rates.
Full throttle changes can be done on a motorbike because the engine weighs **** all so as long as the ECU cuts the spark (on a new bike or one with a quickshifter) when it senses the shift or the rider closes the throttle momenteraly, the engine just matches the road speed very quickly. Some kit car/track car/race car gearboxes can do this, but need to be pretty beefy, so not advisable to try it on the road.
As has been said, it's not necessary with modern synchro boxes. The Police advanced driving test continued using it for some time after (not sure if they still do) as it promotes unhurried shifts.North Wales Driving school were teaching it up to a few years ago but even they may have binned it off now as a waste of time.
Last advanced course I did taught keeping the revs up as soon as you dip the clutch when doing an unhurried downshift to smooth it all out- sounds odd but works
I learned to drive in an old crappy 950cc MkII Fiesta. Throttle on downshifts was essential to keep passengers and driver happy. That car taught me a lot about how to drive smoothly because it was so difficult!
This was supposed to be a troll thread right?
Nope. How many people blip the throttle in the middle of a gearchange - practically none. Of course everyone lets the clutch out gradually and helps by gradually pressing the throttle - that's normal driving. A blipped throttle downchange achieves the same thing but because of the blip it allows much quicker shifting while matching input and output shaft speeds. That's why it's still used in racing and sequential manual boxes like the DSG.
Double de-clutching is not the same as blipped throttle downchange. It has the extra element of letting the clutch up when in neutral and then pushing down again to shift to the new gear, and is only required for non-sycromesh boxes
Mine does not blip the throttle between gear changes. It's never in neutral, this can't happen.
It brings the revs up to match the road speed in the new gear - is that what you mean?
No its not, because the input shaft is to all intents and purposes stationary when the cluch is pressed and the box in neutral.
You could blip the throttle and double clutch, but thats just making the input shaft spin even faster.
Quite interesting side point:
Towing a RWD car can ruin the gearbox, some designs rely on the input shaft spinning to get the oil where its needed.
Massive over sell there!
Things my Dad taught me
Double De-Clutching
Heal & Toe
Left Foot Braking
Lift off oversteer
Racing gear changes! (up shifting without clutch, a lot of crunching learning this one!)
Then after my driving test he put me on a skid pan.The only thing I really use occasionaly is double de-clutching on the downs as I find it smoother, if done correctly.
Reply »
You must log in to post.
