BTW clubber, WTF is that big lump of front mech?
It's an SLX double mech – works much better than a triple IMO. It's not particularly chunky though – I think it just looks that way because the cage is smaller than a normal triple one.
Obi_Twa – Member
I see a big problem with just taking the big ring off a triple to make it into a double. That problem being the absence of a big ring. Unless you live at the bottom of a well and have to ride out every day I dont see why you would want only a middle and granny set up, especially with that muthaf***a of a rear cassette you have on there.
It's been endlessly discussed on here already. For most people it's just not an issue as the top gear is plenty for normal off road riding and fitness will dictate whether the 'muthaf***a of a rear cassette' is necessary or not. Currently I'm not very fit so it's necessary. Back in the day when I was completely the opposite, no doubt I'd have been running an 11-28 cassette with larger chainrings and that's what more racy people are doing.
EDIT – I should probably mention that while mine is a standard chainset, the 'big' chainring is a 36, not a 32 though for most riding I don't actually think even that would be a huge issue.
Finally, chainline. I've had a good look and I did think about moving spacers around before fitting it all but the chainrings are actually exactly where I want them for a double and I reckon adding a spacer to the driveside would actually give you a worse chainline.
