I’ve got an 8 year old bottle and not died.
There’s a breather hole in the lid of most car brake resevoirs, if it can last 2 years in there wihout absorbing too much water, it’ll survive 18month in a bottle with a closed lid. Once it’s dessicated the air in the bottle theres no more moisture to absorb, and the wet boiling point is measured with a suprising ammount of water anyway so the tiny ammount of moist air that got in last time you used it wont affect it.
You replace it in your bike as the seals in the calliper aren’t great when not under pressure, so when you release the lever they’re drawing water in. Which is why 2 year old brake fluid in your brakes is dirty and cloudy, and 2 year old stuff on the shelf is still clear.
