Viewing 10 posts - 1 through 10 (of 10 total)
  • Does this show worn fork bushes?
  • jamesgarbett
    Gently rocking the bike back and forth with front brake applied – slight knocking sound and movement? Headset isn’t loose and forks aren’t extending/compressing.
    guitarhero
    What fork?
    KonaTC
    If you have disk brakes check its not the pads moveing
    jamesgarbett
    Vanilla
    Stoner
    turn the wheel 90degrees and try again (that should isolate any pad movement)
    slartybartfast
    Try storing the bike upside down for a while to let the bushes in the top of soak some oil up.
    swisstony
    if you wrap your hand around the seal on one leg and rock again you’ll feel the movement there if it’s the bushes
    jamesgarbett
    Thanks all
    chrisem
    May just be the pads moving in the caliper. Pull the brake lever on as hard as possible, to stop any pad movement, and try again.
    Doug
    Also check your front wheel bearings, brake caliper mounting bolts and rear shock bushes.
The topic ‘Does this show worn fork bushes?’ is closed to new replies.
