Viewing 40 posts - 1 through 40 (of 51 total)
  • Does it open or close?
  • onandon
    I think close.
    TrekEX8
    Open. Probably
    Or possibly close…
    4130s0ul
    Open (one of us has got to be right!) 😉
    the-muffin-man
    7th gear along jams and chucks off the rubber band.
    Trimix
    Closes.
    The two cross over ones cancel out and the two joined by a belt count as one.
    aracer
    Open. Apart from the second and third cog connected by a straight belt, each cog turns the opposite way to the previous one. 15 cogs including the input cog, hence 13 changes of direction and the final cog turns anti-clockwise.
    sandwicheater
    I’m more intrigued as to what’s in the box. Fingers crossed it’s some 1980 hedge pron.
    maccruiskeen
    If /when it does open – is the cat inside dead or alive?
    TrekEX8
    Trimix, I agree with your reasoning…..but still get open…
    maccruiskeen
    Hang on… its already open to start with.
    That dead cat is going to be long gone.
    TrekEX8
    What tyres for Jeremy Corbyn’s box which might open or close on a conveyor belt. And would it have done the opposite before BREXIT?
    It’s already open.
    amedias
    At first glance it opens*, but that depends on if the ‘string’ attached to the lid gets wound** around the spindle of the last cog/sprocket or not. If it does then it opens, if in fact it winds round a bit and then slips off the end and goes slack as it comes back round then the lid will oscillate.
    if ** is true then * is true eventually no matter what direction it turns, but if it goes the ‘other’ way to the image then it would initally close a bit, then open and keep opening as the string wound round the spindle the other way.
    Bregante
    Yes.
    Rorschach
    I concur
    Also
    [video]https://www.youtube.com/watch?v=Z86V_ICUCD4[/video]
    CaptainFlashheart
    Took this picture on a recent flight. This was on the inside of the door. The button was on the outside.
    fasthaggis
    Nope
    [video]https://youtu.be/2lQBsMVAK5o[/video]
    perchypanther
    Took this picture on a recent flight. This was on the inside of the door. The button as on the outside
    Did you kick the door open with your “special” shoes? 😉
    Took this picture on a recent flight. This was on the inside of the door. The button as on the outside.
    I hope you used one of your post-it notes to correct it?
    zinaru
    opens
    slowpuncheur
    Is it an exploded diagram of a prototype 15 speed cassette? Only a matter of time..
    It closes. I now need to find out. Can someone please built it?
    Cougar
    Opens. Obvs.
    CaptainFlashheart
    🙂 Was wearing flip flops.
    This is from the same trip, though,
    MrSparkle
    It opens even further and breaks the lid off.
    P-Jay
    If I made it – break.
    andytherocketeer
    Open, then lift the box up by the lid.
    Did they ever fix the £2 coin, so that the cogs on the reverse of that could actually turn?
    aracer
    You seem to be assuming the box isn’t superglued to the floor and that the cogs are firmly attached in place.
    tuskaloosa
    Open
    cynic-al
    Open, easy peasy
    shermer75
    Close 🙂
    shermer75
    15 cogs -2 sprockets that are connected by the crossed belt = 13 cogs = 12 changes in direction ? last cog rotates same direction as first ? closes.
    Cougar
    Crossed belt is the same as directly connected. It’s the uncrossed belt that’s made you wrong.
    captainsasquatch
    Iirc I had hundreds of this sort of thing to do during an exam/interview for the Navy.
    Closes.
    shermer75
    Two cogs joined by a crossed belt rotate on the same direction so they can be thought of as being one cog. So four cogs with crossed belts = 2 cogs. The cogs with the straight, uncrossed belt rotate in opposite directions so can be counted as normal 🙂
    shermer75
    Ah- actually, you’re right and I’m wrong. Opens!!!
    stumpy01
    Open….
    shermer75 – Member
    Have a think about the chain on your bike…..and the consider revising this statement….. 🙂
    nickdavies
    Open. I’m right cos I didn’t try and use maths I just followed it with my finger! 😆
    Klunk
    cw-ccw-ccw-cw-ccw-cw-ccw-cw-ccw-cw-ccw-cw-ccw-cw-ccw = open
    Kahurangi
    It won’t take off, and certainly not from LHR, never going to get built this century.
The topic ‘Does it open or close?’ is closed to new replies.
