• This topic has 18 replies, 12 voices, and was last updated 11 years ago by GW.
Viewing 19 posts - 1 through 19 (of 19 total)
  • Does anyone stock a 7mm headset spacer??
  • DrP
    Being a bit ‘aiming for perfection here’, I acknowledge, but I’m after a 7mm headset/stem spacer, and can’t find one anywhere!!!
    Crc, eBay, etc etc
    Does anyone know which direction to point my money at at all??
    Ta!
    DrP
    (In a typical stw fashion, awaits this thread to contain comments telling me “not to look for what I’m looking for”, alternatively the thread being closed after a heated discussion about racism and the rights and wrongs of child pornography!!!) 😉
    bruneep
    damo2576
    Never seen one. But 5mm and 2mm are available…
    khani
    I’ve never seen one, you may have to cut down a 10mm instead, carbon ones with a fine hacksaw blade cut neatly..
    You Racist Nazi Pervy bastard….. 😀
    DrP
    I found bmx ones, but bmx = 1 inch, no?
    DrP
    bruneep
    <sigh> you never stated 1 1/8″ or 1.5″ 🙄
    Typical unclear post by STW poster who asks for help but doesn’t give the full information reqiuired. 😉
    jota180
    A 10mm one, then a trip to a hobby shop or a small engineering place to have it whittled down on a lathe?
    schmiken
    Chris King do 6mm ones?
    thepurist
    High On Bikes have this lot on eBay that includes a 7mm, but if you really really really only want the 7mm just give em a call and ask nicely.
    DrP
    Cheers thepurist, have contacted them about individual spacers!
    Filing that, I’ll just have to clamp the stem down using a 5mm spacer on top, then remove it when he stem is tight.
    DrP
    cynic-al
    No one has asked…why?
    A customer in my last lbs job wanted 1mm spacers so he could get his TT stem position “just right”. Yup, he was and is a **** 😀
    mattjg
    Worked in a ski hire shop once, had a customer bring skis back “because they wouldn’t run parallell”.
    GW
    1mm is hardly “perfect” I use two 0.2mm spacers and no top/dust cap under the top crown on my DH bike to achieve near perfect clearance to run the fork as raked out as possible without resorting to a drop crown (which would cause all sorts of other “issues”)
    My bar height is always adjusted to within +-1mm, why wouldn’t you?
    wwaswas
    because the grips and palms of my gloves probably have more than 1mm ‘give’ between them.
    damo2576
    Tsk. You need some better gloves.
    scruff
    Middleburn do all sorts.
    GW
    Waswas – you’ve clearly never seen my “grips” or “gloves” 😆
    DrP
    Don’t want any spaces above the stem, and essentially the steerer needs another 2mm off it, which I’m not going to achieve…..
    Don’t want to run a 10mm spacer below as that will be a few mm too little steerer clamped in the stem……
    DrP
    GW
    That may look tidier but ahead stems clamp your steerer more securely with a spacer above.
The topic ‘Does anyone stock a 7mm headset spacer??’ is closed to new replies.
