I just had ChrisL’s mega 290 for what sounds like a similiar cracking/creaking noise, it’s 4 months old. Inevitably the SRAM BB is worn out, because they’re as shit as ever. But the main pivot and horst link bearings are also quite badly worn and approaching needing replacement. The rocker bearings were all fine
I don’t actually know what was causing the crack/creak- I did a full strip, clean and lube of pivots and bearings and it’s apparently fixed it. There was a wee bit of wear on a spacer which suggested it might have been rubbing, I think that was brakeside horst linkage. Or maybe it was just the clean and grease.
The main thing is they are cheap, shit bearings- I opened one up to inspect and there’s no dirt or water ingress, it’s purely low quality. So I wouldn’t be shocked to hear if some are DOA or worn out almost instantly. Also the main pivot bearings are really pretty small, they’re 6902s IIRC.
The good news is in this bike’s case it seems there’s nothing inherently wrong, it’s a dick move from CRC to save a pound but it’s easily fixed with more suitable parts. And it is a bloody brilliant bike otherwise. I’d consider all this stuff to be warranty, but it also fits into “pain in the bum warranty” and at the end of the day if they replace with the same parts it’ll run straight into the same issue in 5 minutes so I think we’ll go down the quality replacements route.
