Viewing 40 posts - 1 through 40 (of 45 total)
  • Do you think this photo is legit ? Skiing photo
  • FunkyDunc
    Someone on my FB posted this picture. Don’t get me wrong I have no doubt that it’s steep, and he is a very very good skier, but the grass puzzles me, I didn’t realise grass could cling to such a steep slope….
    Interesting clouds. 😀
    40mpg
    Clouds and inversion layer 😕
    Pook
    Mbuk photographer must be on holiday
    nickjb
    Very sticky snow or not as steep as the camera angle wants to make it look.
    scotroutes
    Aye – not quite, err, horizontal…..
    scaredypants
    DT, that’s magnificent
    scotroutes
    Might also ask what is causing his shadow to be cast “up” the mountain behind him.
    Spin
    Yeah, not right.
    Spin
    Do you know where it is?
    scaredypants
    (wondered how long that pic would last !)
    muppetWrangler
    That’s about 30 degrees out based on clouds and body position.
    davidtaylforth
    scaredypants – Member
    I knew it wouldn’t last, I’ve had it deleted before. But for this topic especially, I thought it was worth a repost. Rotating a picture to make it appear steeper and then posting it to your friends on facebook…..he’s got to be one! We’re all adults now….simply no need.
    dovebiker
    More commendable are the telemark skis.
    I have skied on steeper in my youth, it’s pretty hairy as you have to jump turn – I learnt to ski in Scotland, where technically it wasn’t always snow, but included a mixture of snow, ice, rocks and heather!
    captainsasquatch
    Can’t work out which bit is photoshopped as the peak looks ok.
    mrhoppy
    Out by enough that when I try to spin my phone to line it up it auto rotates. 😀
    It’s still pretty steep mind.
    Edukator
    If he were any good he’d be heading straight down. The lower ski is probably flat and the lower ski pole vertical.
    CaptainFlashheart
    SN3 1TX
    rotated back to where I reckon it should be
    TheFlyingOx
    It’s probably a reflection of the sun from the mountain slope opposite, which will likely be casting the reflection upwards. Skier is on the shaded side of whichever mountain that is.
    gravity-slave
    More like this, not that steep going from feet position.
    sweepy
    You are all underestimating that bloke, check out this pic of him climbing
    Spin
    Doesn’t look like he’s telemarking to me.
    legend
    Surely it all depends on what wax he’s using?!
    Edukator
    Jean Marc Boivin was the man who could ski steepest back in the 80s when the approach was to pick ones way down with jump turns, from 56s:
    Boivin
    These days they just head straight down at terminal velocity.
    Spin
    Boivin was a visionary but he wasn’t alone, there were others skiing as hard as him.
    wallop
    😆 Legend
    shermer75
    Hmmm, ‘la neige’…
    [video]https://m.youtube.com/watch?v=bsqLi9LfiwM[/video]
    jambalaya
    OP you should repost the rotated photo to his timeline and comment on his post about the clouds being at a strange angle
    deadkenny
    legend – Member
    That all depends where it is. Got to be the right wax for the location 😉
    nedrapier
    sort of, better knowledge about snow stability today means that people are skiing lines in soft snow that Boivin et al would wait to be firm as hell before they tried, and so they’ve got more to get their edges into, more safety margin and better equipment.
    But get into the realms of true extreme skiing, the snow’s never going to be “good” and there’s still a heck of a jump turns:
    Nant Blanc Route Repeated
    Edukator
    [video]https://www.youtube.com/watch?v=usmrbygeub4[/video]
    At 1:22 for example – straight down taking air over the steep rock rather than trying to ski around it. Things have moved on, some of the 80s lines still need to be shuffled down but others are now skied straight.
    nedrapier
    Things have moved on, people are skiiing faster and straighter, but those lines in your clip are all lines with big run outs, chosen for filming because they’re a notch or two below the skiers’ max gnar levels so they can be skiied quickly and fluidly.
    Totally different ball game to the downhill alpinism type of lines that Boivin, Siffredi, Tardivel, Rhem and Ruby, Gouvy, Fransson pushed (spot the odd one out 🙁 )
    nedrapier
    too late to edit:
    spot the odd one two
    Edukator
    I think we’ve all seen this before, max gnar skied quickly and fluidly:
    [video]https://www.youtube.com/watch?v=xlXk49Mh7go[/video]
    scaredypants
    to be fair, Edukator, I’ve been on iced-up mountain roads (in Val D’isere with the wrong wax 😯 ) pretty much like that, but with a ski-school to overtake as well
    dirksdiggler
    I’m going to defend the guy here.
    .. In a way.
    He’s clearly not skiing, but shitting his pants and stepping down. See his tracks above and that he is holding his pole at half mast.
    He got through it though and probably felt like he escaped death. His mate who took the photo showed him in the bar that night… And remembering how f*ing steep it *felt* he thinks the photo reflects the situation he was in and was a fair representation of his experience that day. So.. Posts on FB.
    Fair enough I reckon
    aracer
    I’d be wanting grip wax
    singletrackmind
    Who holds their ski poles like that?
    Plus it looks like a snowplough turn is being attempted in a vain effort to slow down .
    To be fair , Looking at the snow cover ( grass / rocks etc ) He is more likely picking his way down between some exposed rocks as it is skinny.
    Below the photo might be a lovely chute with alot of snow in it,just the entry has been wind scoured ( cornice blown at top of pic )
    aracer
    People skiing genuinely steep stuff (which that still is even with the photo correctly rotated). As for the suggestion of a snow plough, which edge of the skis do you use when doing a snow plough? A slight stem certainly helps set up a short radius turn when the terrain is close to the limit of your abilities (I’m sure a god could keep their skis parallel on that, but for ordinary mortals you get down however you can).
The topic ‘Do you think this photo is legit ? Skiing photo’ is closed to new replies.
