Viewing 19 posts - 1 through 19 (of 19 total)
  • Do you think i can fix this?
  • damascus
    esselgruntfuttock
    No but you could stop asking silly questions.
    andrewh
    Blob of araldite, it’ll be fine.
    mjsmke
    Nothing a bit of blu-tack wont fix.
    damascus
    A bit of duck tape and a zip tie?
    paulosoxo
    Send them to me, and for £399.99 I’ll have them back to you, looking like new, complete with chainrings.
    PayPal gift?
    matt_outandabout
    HOW?
    seadog101
    Trail fix it with a stick though the middle.
    paulosoxo
    HOW?
    Overtightened the preload thingy, I bet 🙂
    Keef
    u is awsum…….
    It’s just a sticker. Nothing to worry about.
    shedfull
    Blimey, it tore the bearing out of the BB cup!!
    andyl
    Landing from a jump/drop by any chance? Looks like a torsional failure. Nice one.
    I guess technically you could get someone to weld/braze a tube/shaft up the middle but realistically sell the none drive side and hang the drive side up and be proud.
    slackalice
    What do you think? 😕
    ac282
    Must have installed them with a rock.
    OCB
    I’d do the same kinda thing as if I were making a DIY headset press, so just poke a bit of studding through the middle, shove a fat repair washer on either end, topped off by a nyloc (or a domed nut if you are feeling posh) and crank it down with a couple of foot of scaffolding pipe on the end of the spanner – what could possibly go wrong?
    I guess if you were concerned, you could shove a bit of MDPE water pipe or something over the studding to save it moving around too much in the BB shell?
    scaredypants
    This is a classic failure – I bet the OP fitted 650b wheels and the enhanced trail liveliness has fed back up the drivetrain
    It’s lucky the axle failed – your ankles were next in line
    mick_r
    The spiral bit is a classic torsional failure.
    I think you already know the answer about repairing them….
    garage-dweller
    That will just T cut out.
The topic ‘Do you think i can fix this?’ is closed to new replies.
